2009 Jetta TDI. I bought it Friday and picked it up yesterday. It is the nicest car that I have ever owned.
Carry on.
True, I was looking at the wrong model generation (they no longer produce in Bosnia, I wonder why...).Sisyphus wrote:...Or Mexico.
Thanks for that! I'll check it out.Sisyphus wrote:http://www.tdiclub.com/
I took a road trip today, and I thought I would post some statistics from the MFD in case you were interested:Sisyphus wrote:Don't know what the new ones get, but my 99-1/2 gets upward of 47 mpg. With a few mods and changes in drving style some guys are getting 60 or better.
Interesting, I used to work with a tilesetter w/ a VW truck-thingy that he converted to, as you call it, greasel. He hated the way the car ran but he made the fuel himself and had been running it essentially for free for over three years. But again, he only used that car for work. I recall it was hell to start up at th end of the day, also. So that colored my opinion of biodiesel assuming it was all poor quality like that. Mayhaps I was wrong.Beltway wrote:You probably already know this, but...
There are two different types of fuel that folks often confuse with one another. One is Biodiesel, the other is Waste Vegetable Oil (WVO) or Greasel.
Biodiesel has had the glycol settled out of it in a process known as transesterification and can be mixed with dino--diesel in any proportion without any further treatment, additives, heaters or whathaveyou. There are almost certainly local manufacturers/refiners in your neck of the woods, which means you can support the local economy and run your vehicle on fuel that did not require long-distance transport.
Bio also has higher lubricity (much loved by your fuel injection system) and produces lower NOx emissions.
Greasel, on the other hand, is simply filtered (down to 2 microns) waste vegetable oil. It needs to be heated to around 150 degrees before it will behave like dino-diesel. This means it needs a separate tank with a heater (usually electric or engine-coolant based) and a solenoid that allows you to switch between the dino and WVO tanks. You have to start the engine on the dino and run it until the WVO tank is up to temp, then switch over. It is equally important that you switch back to dino and run the motor on that for a few minutes before shutting down, otherwise you'll have fuel lines and injectors full of congealed fat and much cleaning to do.
Anywho, the point of this was to say that you can use high-quality biodiesel in your VW without doing anything but putting it in the tank. The newer models have the right type of fuel lines and seals (viton) so you really shouldn't have any trouble. Check out the various tdi sites to make sure yours is compatible.
Enjoy your new ride!
