Real-Life MC Escher...
Post by Jaeger » Wed Feb 16, 2011 11:36 am
I'm sure this is some perspective/optical illusion, but still...
<iframe title="YouTube video player" width="640" height="390" src="http://www.youtube.com/embed/ZsZzH0a7dwc" frameborder="0" allowfullscreen></iframe>
Vance
Post by Vance » Wed Feb 16, 2011 1:29 pm
I'm waving the CGI flag here...
Watch the way the water moves from :39 to :53'ish. It skips... it doesn't move properly. Then as it continues the water doesn't move the way it should along the walls if you look carefully.
With the first link, the chain is forged. The first speech censured, the first thought forbidden, the first freedom denied – chains us all, irrevocably."
- 2001 Aprilia RSV Mille R
Post by rolly » Wed Feb 16, 2011 1:41 pm
Actually, I think that indicates that it's not cgi, because why would you intentionally animate the water that way if you were trying to look convincing? In fact, making the water flow the way it does in the video would be more effort to rig than more natural flowing water.
The model's real geometry isn't what you see so the water on it doesn't appear to behave correctly. Here is a (low quality, non embeddable) video of another realization of Escher's waterfall that shows it from a different angle, which shows how it might have been done: http://www.milkandcookies.com/link/44839/detail/
Pintgudge
The Big Oooola
Post by Pintgudge » Wed Feb 16, 2011 3:17 pm
I don't know how he did it, but if I wanted to do that, I would build it as seen, and put sheets of clear plastic mounted 1/16" above water surface with a battery operated pump in the box below the wheel.
pour in water, water fills box area with pump, pump pumps water between wood and clear (invisible) plastic up to the top and down over the wheel.
I think this would account for the oddness of the water movement.
So, there!
If man is fit to be governed, is any man fit to govern?
These are the days of miracles and wonder!
'81 Goldwing Standard w/'61 Ural Sidecar
'06 Bajaj Chetak
Mean Chuck
Delaware Destroyer
Post by Mean Chuck » Wed Feb 16, 2011 5:51 pm
For some reason I was expecting this-
<iframe title="YouTube video player" width="480" height="390" src="http://www.youtube.com/embed/-ZqKwdqBmSE" frameborder="0" allowfullscreen></iframe>
