Fire extinguishing grenade
Posted: Sat Apr 09, 2011 3:16 pm
This looks intriguing:
<iframe title="YouTube video player" width="480" height="390" src="http://www.youtube.com/embed/WeWs8Aqo2Fk" frameborder="0" allowfullscreen></iframe>
To me that looks like a seriously burning fire, but I may be wrong.
Now, someone should adapt this to 40mm caliber for grenade machine guns to mount on fire trucks...
Posted: Sat Apr 09, 2011 6:26 pm
by Sisyphus
That's awesome.
Wonder what it is, must be some chemical that breaks the combustion chain, because it isn't cold and it doesn't displace oxygen.
One of the best firefighting chemicals here in the US was eventually outlawed because it was too hazardous. Purple K.
Posted: Sat Apr 09, 2011 6:42 pm
by rolly
Really curious how it works, if it works on anything larger than a small shed, and if there was a person in the room where one goes off would they survive the extinguishing.
The guy throwing a scoop of water (or something?) into the fire after the extinguisher grenade is interesting, don't know the significance of it.
Posted: Sat Apr 09, 2011 11:27 pm
by Jonny
The voice-over talks about ammonia gas and "tansan" gas (tansan generally refers to a liquid being carbonated or bubbly) and then something else that I don't get.
rolly wrote:The guy throwing a scoop of water (or something?) into the fire after the extinguisher grenade is interesting, don't know the significance of it.
I assumed that was the liquid in non-grenade form. Dunno...
Posted: Mon Apr 11, 2011 3:15 pm
by JoJoLesh
watched another vid on it...
Seemed like that Water-like substance was kerosene. Proving that combustion has been truly halted? IDK about that, as the fire semes to go out when he throws it.
I'm seein the grenade as a Rescue tool in that vid. As in when you know someone is behind that wall o fire, you throw grenade clearing path to drag victim out
http://www.youtube.com/watch?v=Fn-r4a4w ... r_embedded
Posted: Wed Apr 13, 2011 12:40 pm
ah-hA!
some guy quoted on geekologie wrote:You huck it at a fire, and the shell, made of fragile plastic, breaks, unleashing both a fire-extinguishing liquid agents, and chemicals that mix to release carbon dioxide and ammonia, which force out the oxygen and smother the flames.
http://www.geekologie.com/2011/04/makin ... n-agai.php
Posted: Wed Apr 13, 2011 1:33 pm
by JoJoLesh
and what does the Ammonia do? Not feeling very chemist at the moment
Posted: Wed Apr 13, 2011 3:13 pm
by Sisyphus
Not a chemist but I've been to fire school more than once, and I think maybe the ammonia bonds with the oxygen, making it unavailable for cumbustion. That's how drychem extinguishers work. CO2, of course, will put out a fire but has to be present in such a volume as to displace the oxygen. That's a huuuuge volume. But if you had something that could bod with the O, then your problem is solved.
I think this is an awesome idea and could go far in saving lives and property, provided it's done safely and effectively!
Posted: Thu Apr 14, 2011 6:39 am
Sisyphus wrote: I think this is an awesome idea and could go far in saving lives and property, provided it's done safely and effectively!
Like I said. Grenade-machine-gun.
