If I had a first aid kit it would contain:
Duct tape
Ibuprofen
(a goodly bit of) Gauze
Assorted band-aids
Quick Clot (more effective than cauterizing with a hot iron, and nearly as uncomfortable!)
Tourniquet
Some 550 cord
A few Percocets, in case I actually ever NEED the superglue and duct tape. If I am damaged that bad, Advil ain't going to cut it.
That's enough to improvise most things, and doesn't take up much room. I was going to add superglue, but sealing a wound bad enough to need stitches is usually a bad idea - either you are going to get to a hospital pretty quick, in which case it's unnecessary, or it's going to be a while, in which case it's begging for a bad infection due to you sealing trash up in the wound.
Merlyn
First aid kit
Merlyn
- 2007 FXD/Dyna SuperGlide - Black Betty
- 1986 Intruder 700 - Work in Progress
Some days you can look to your left as you ride and see your Valkyrie- pacing you and waiting for her moment...
Days like that, the only appropriate reaction is to call out "Let's dance, beautiful!" and then twist the throttle to it's stop.
Remember, folks- Your vote means fuck-all. If voting could actually change anything it would have been outlawed long ago.
The only votes that mean anything in this day and age are made from rooftops.
