I found out today what the nano-machine in my lab is for.
It's used to make teeny tiny EDM tools, which are then used to form microchip wafers, which are then used to make tiny little, non-mechanical, experimental gyroscopic devices for DARPA.
And apparently it pays very, very well.
OK yeah it was Nanu but whatever.
OH NO! GRAY GOO! WE'RE ALL GONNA DIE!
Or, that's really cool. More scoop when you get it please.
It's a guidance system for one of these.
<object width="560" height="315"><param name="movie" value="http://www.youtube.com/v/VxSs1kGZQqc?ve ... ram><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/VxSs1kGZQqc?version=3&hl=en_US" type="application/x-shockwave-flash" width="560" height="315" allowscriptaccess="always" allowfullscreen="true"></embed></object>
Tiny shit is soooo fucking cool.
Trav
- Captain Delicious
I think if you align the so-tiny-they're-invisible universes just so, they act like a motorcycle wheel.DerGolgo wrote:Neat. But...non-mechanical gyroscopes? WTF? Something with electron beams, I assume?
May God help us all. Destroy that machine. Save us from ourselves!
Also.
"With the engine running in the neutral position, disengage the clutch (pull in-clutch lever), press down on the shift lever until low gear is engaged, remove foot from shift lever, increase engine speed slightly, slowly release clutch lever while advancing throttle. Repeat procedure for remaining gears."
