by DerGolgo » Sat Sep 26, 2009 2:41 pm
I was looking for a pic of the local FD's new heavy mobile crane which I encountered on the motorway the other day, couldn't find it and asked a buddy. He couldn't find it either, but he did come up with this from the volunteer FD's website where they show off their kit:
Yes, it's a waterpump for getting water out of rivers and other open bodies of water for the purpose of putting out fires.
I wonder how much hp they have it producing, obviously they wouldn't run it at the sort of rpm you can get away with on a bike on the road for shorter periods.
EDIT: Found the mfg. Doesn't mention displacement, but does mention double ignition, 68 hp @ 4100 rpm. Picture on the website is of the current BMW GS, makes sense they changed to the new engine when BMW stopped making the old one. So, it stands to reason the previous one was similar, most likely the 1150 I'd think.
by Bigshankhank » Sun Sep 27, 2009 4:21 am
Man, how long before some bored firefighter/machinist puts that in a bike frame?
by dozer » Sun Sep 27, 2009 6:06 am
Reminds me of the Gullenpumpe, AKA CX500 motor that someone made into a real shit pump...
Sisyphus wrote:
If, on the other hand, a full-on revolution starts within one year, you will provide me your mailing address and I will send you the balsa wood box for you to eat. Provided I haven't already eaten it. In which case I will send you an object of equal or lesser value that hasn't been eaten, provided it is as edible as balsa and is of nearly equvalent volume (empty).
by Bigshankhank » Sun Sep 27, 2009 11:14 am
dozerone wrote:Reminds me of the Gullenpumpe, AKA CX500 motor that someone made into a real shit pump...
As in a septic pump? Sounds glamorous.
by DerGolgo » Sun Sep 27, 2009 11:19 am
Bigshankhank wrote:dozerone wrote:Reminds me of the Gullenpumpe, AKA CX500 motor that someone made into a real shit pump...
As seen in this biker comic from the early eighties:
Farmer Horst's liquid-manure pumpe had failed and he was very sad. But not to worry. Werner only had to listen till he beheld the sounds of a CX500, pulled it over and voila, problem solved.
by dozer » Mon Sep 28, 2009 4:09 pm
HA!
by goose » Mon Sep 28, 2009 4:40 pm
damn BMW, even their water pumps are ugly! Hideous lump of ....
by DerGolgo » Tue Sep 29, 2009 11:27 am
goose wrote:damn BMW, even their water pumps are ugly! Hideous lump of ....
Hey, now, this is unfair.
The pump is made by
Rosenbauer. You can't blame BMW for the
entire ugly.
Here's the current model:
Check it out, they actually made one as far back as the pushrods:
